Hood and Trunk props colors
- Aris Loumidis
30 Jun 2020 11:17 #40449
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Hood and Trunk props colors
τηανκσ γθυσ
Thanks guys I will try the cadmium plating with the Eastwood spray. I still have one from many years back, if no good I will get a new one.
Here's the link www.amazon.com/Eastwood-Acrylic-Lacquer-...erosol/dp/B07Q5G6KN2
Aris Loumidis
Athens, Greece
ACD Life Member
______________
28 Jun 2020 23:36 #40441
by uconn_1965
Replied by uconn_1965 on topic Hood and Trunk props colors
I think that the flat back trunk lid, the bustle back trunk lid, and convertible trunk lid springs are all different.
The following user(s) said Thank You: Aris Loumidis, 1748 S
28 Jun 2020 13:45 #40434
Replied by 1748 S on topic Hood and Trunk props colors
I believe both are supposed to be cadium plated silver but.. I'm also told that as the end of production they were painted black too. I have seen cad plated ones and they look great. Remember both hood and trunk supports had a spring to lock them in place as they were opened. The trunk had a flat wound spring where the hood had a coil wound spring. Usually the trunk spring breaks and the hood spring ends up missing.
- Aris Loumidis
28 Jun 2020 12:30 #40433
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Hood and Trunk props colors was created by Aris Loumidis
Hi all!
My trunk prop is painted grey-silver and the engine hood prop is painted Ivory as is the body color.
Is this the original correct way they should be?
Aris
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
