- Thank you received: 25
Cord chassi 1386 information
- E L
03 Mar 2020 20:11 #39642
by E L
Replied by E L on topic Cord chassi 1386 information
2586A, FB1786 C90 1355 in the master list was in Brazil as early as 1966.
Possibly earlier
Possibly earlier
- fleibel
02 Mar 2020 19:44 - 02 Mar 2020 19:47 #39640
by fleibel
Replied by fleibel on topic Cord chassi 1386 information
Good afternoon, My Cord is a Sedan with engine number FB 1769. For the history that I raised it is one of the only Cords exported to Brazil in 1937. Attached photo of the car.
Last edit: 02 Mar 2020 19:47 by fleibel.
- Tim Gilmartin
- Thank you received: 57
02 Mar 2020 17:37 #39639
by Tim Gilmartin
Replied by Tim Gilmartin on topic Cord chassi 1386 information
Other info: car was in Minnesota in 2014, no owner name. Serial number plate of 2386F was for sale on EBay in 2005. I’m also showing the original engine number was FB 1478; current engine is FB 239. Central Manufacturing body number was C 92 128.
I hope this helps.
I hope this helps.
- Tim Gilmartin
02 Mar 2020 17:31 #39638
by Tim Gilmartin
Your photo shows the stamp on the frame, called the “unit number.”
Add 1000 to the unit number to get the serial number, or 2386. If you have the serial plate, then 2386 should be there along with the engine number.
The only car I show with a 2386 serial number is a 1936 Convertible Coupe (two seatconvertible). Is this what you have?
- Lycoming288
02 Mar 2020 01:55 - 03 Mar 2020 01:35 #39637
by Lycoming288
Replied by Lycoming288 on topic Cord chassi 1386 information
9/9/36 "In accordance with the decision to change the serial numbers on the 810 Cord models to Model 812 models, we have prepared a list showing the serial number limitations on those cars as follows:"
1 - Show Cars: Model 810 Show cars to Model 812 - 1001 to 1100 inclusive"
2 - Cars in Branches (Production models): Model 810 to Model 812, 1101 to 1400 inclusive"
3 - Production cars in factory: Model 810 to Model 812 - 1401 to 1525 inclusive"
Cars to build: First model 812 off the line will be 1526"
- Maurice Glose
Excerpt from Pg. 23 of "810-812 Engineering Changes" reprinted by Joe Knapp, published July 1960
Your car is included in this information.
Cort Stebbins #1477
- Maurice Glose
Cort Stebbins #1477
Last edit: 03 Mar 2020 01:35 by Lycoming288. Reason: Add digit to correct item 2 (1101 to 1400)
- fleibel
01 Mar 2020 20:13 #39636
by fleibel
Terry,
Tks a lot!
Tks a lot!
01 Mar 2020 19:50 #39635
Replied by Terry Cockerell on topic Cord chassi 1386 information
Is your Cord an 810 or an 812 ?
My Cord is the 810 with Serial No 810 1586 A that you referred to, however it is located in Australia but was originally sold in Canada.
Jack Richards in Missouri will be able to help you with the identification.
[email protected]
[email protected]
- fleibel
01 Mar 2020 10:52 #39633
by fleibel
Cord chassi 1386 information was created by fleibel
Good Morning, I'm trying to find the data for my Cord model and year. We found the inscription on the chassis but we are unsure whether it is printed 1586 or 1386. I already have the information that the 1586 chassis car is in Canada and I even read an article on the web about it. Based on that, I believe mine is 1386. Any body have access to the book with the records and could search for 1386 data? I send an attached photo of the chassis. Thank you very much in advance
