Front brake drum nut torque
03 Mar 2020 02:42 #39641
Replied by JIM.OBRIEN on topic Front brake drum nut torque
If the wheel turns easily then I'm in good shape! If the nut turns easily I invent new words.
28 Feb 2020 03:17 #39615
Replied by mikespeed35 on topic Front brake drum nut torque
Hi Jim, What do you do when it SQUEELS and then turns easily!
27 Feb 2020 16:22 #39609
Replied by 1748 S on topic Front brake drum nut torque
No eBay APP ID and/or Cert ID defined in Kunena configurationI just checked ebay and found this easily.
27 Feb 2020 15:59 #39605
You might be able to rent a 3/4 drive torque wrench from a rental yard too. Calling costs nothing. Just a note about sockets for this particular job. But an impact socket. Check EBAY for the brand JH Williams or Proto. Williams is a great oil field tool used all the time in the steam generation plants.
- trimacar
27 Feb 2020 13:24 #39604
by trimacar
Replied by trimacar on topic Front brake drum nut torque
Just talked to my buddy, he has a torque wrench that goes to 250, and the nut is at least that tight, probably more, so sounds like we're in the ball park..thanks dc
- trimacar
27 Feb 2020 13:17 #39603
by trimacar
Thanks very much! We're in the process of getting my car back together, as I've told you it was very neglected for a long time, although it ran and drove, there were a lot of issues....
27 Feb 2020 12:55 #39602
HI David. The axle nut should be tightened to 300 ft-lbs. Since most of us don't have that big of a torque wrench I was once told to do it this way - get at least a 3' cheater on the end of your wrench and tighten it until it really squeels!
SAFETY WARNING - This is not the place to use cheap Harbor Freight or flea market 3/4" drive socket set or a crescent wrench. Get a good socket and breaker bar!
Earlier this week I grabbed my cheap socket and breaker bar (I was being lazy and thought the nut was loose) and broke the socket and was no where near the required torque! For this job I have a socket welded onto a 3' piece of 1 1/2" solid steel bar. yes it is very heavy but it has never bent or broke!
- trimacar
27 Feb 2020 12:33 #39599
by trimacar
Front brake drum nut torque was created by trimacar
I know this is a simplistic question, the nuts that hold the brake drum to the front drive shafts, to what torque should they be tightened? Thanks David Coco Winchester Va.
