- Thank you received: 44
A "screwy" question
- wynlaidig
30 Mar 2019 14:09 #36919
by wynlaidig
Replied by wynlaidig on topic A "screwy" question
I start with fastenal.com
- Roads2run
30 Mar 2019 13:10 #36918
by Roads2run
Roads2run
Replied by Roads2run on topic A "screwy" question
Also, McMaster Carr has drawings with dimensions of all of there bolts etc. Tom Hartz
Roads2run
30 Mar 2019 04:50 #36917
Replied by mikespeed35 on topic A "screwy" question
McMaster- Carr has everything you will probably need in about any material you would like.
30 Mar 2019 00:24 #36914
Replied by JIM.OBRIEN on topic A "screwy" question
Hi Bill,
These days the screw head sizes are standardized. I'm sure you can find these on line. For a lot of these screws I use www.restorationstuff.com . They have a lot of standard sizes and heads.
The two large screws for the headlights are special order. I would have to measure one up to get the size. They should be chrome plated.
- wcoye
29 Mar 2019 17:15 #36909
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
A "screwy" question was created by wcoye
I'm finding slotted head machine screws are impossible to find in my local hardware stores, big or small. In searching the web I'm having trouble figuring out the head size for the slotted screws I do find. I 'm just looking to find 2 screws for my transmission cover. Anybody have a reliable source for these? Also what is the proper sized screw for the 2 large screws on our headlights? I think mine might be slightly under sized. Mine have been painted but I'm asumming they should be bright.
Thanx, Bill
Thanx, Bill
Bill Coye
Westchester 2240A
