How to separate the shaft from the steering box?
- Aris Loumidis
12 Dec 2022 08:23 #46559
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Steering shaft
Hi Mario,
This is Aris Loumidis from Greece, I have sent you a PM about the steering box problem I also have on my 810 Phaeton, I would appreciate the pictures if you still have them!
Thanks Ahead,
Aris
Thanks Ahead,
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- T_Hussey
08 Apr 2012 13:23 #22564
by T_Hussey
Cheers,
Tom Hussey
Replied by T_Hussey on topic How to separate the shaft from the steering box?
Perhaps these links would be of use...
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11083[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11084[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11085[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11086[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11087[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11088[/url:2v8q7e2a]
[url:2v8q7e2a]http://restorecarsclassifieds.com/wiki/show_pdf.pdf?n=11089[/url:2v8q7e2a]
The information is not specific to Cord, but does list the Gemmer model 330.
Cheers,
Tom Hussey
- George van Nostrand
- Thank you received: 35
07 Apr 2012 18:14 #22560
by George van Nostrand
Replied by George van Nostrand on topic CORD steering gear.
Item deleted
- oldbanger71
20 Feb 2012 13:53 #22273
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic How to separate the shaft from the steering box?
I had the problem that with my custom beverly project, the Steeringcollumn was of a Westchester and therefore to short, what i did was, i organized a original Custom Beverly steeringjackettube ( which is longer, thanks Henry for instruction and tube ) cut the steering collumn and filled in the additional length with a joint sleeve piece that is fitting snuggly and secured by two setscrews on each end, now why should that interest you ? This way i can extract the Steeringbox without taking of the Steering Wheel, collumn and exhaustcollector.
This solution will not work for you now, but would next time, if you ever need to work on it. Not that i urge you towards that idea to perform on your 'box but is surley a benefit from my extension that was needed. By the way, i did not weld, because welding is allways a problem to get it absolutley straight without turning on a lathe. Best regards Philipp
812 310 121 S
- BradC
17 Feb 2012 04:06 #22237
by BradC
Replied by BradC on topic How to separate the shaft from the steering box?
Thanks, Mario. I knew it was a possibility that the worm was pressed on, but I guess I was still hoping for an easier solution. I don't expect to have to trouble you for pictures, but I appreciate the offer.
Brad
Brad
- vaco
16 Feb 2012 10:57 #22225
by vaco
Replied by vaco on topic Steering shaft
Brad, the worm is pressed fit to the steering shaft (no way you can remove the steering box without the steering shaft, i.e. you have to remove from the car the steering box with the shaft as one unit. If you would like some pictures please pm me (I have done it on two cars). Mario
- BradC
16 Feb 2012 01:37 #22219
by BradC
Thanks, George.
I assume that when I take the cover off I'll find a nut holding the worm on the steering shaft? Anyway I'll go ahead and take the cover off and hopefully it will be obvious how to proceed.
Brad
Brad
16 Feb 2012 00:18 #22217
Replied by George van Nostrand on topic cord steering gear
Brad; The Cord uses the Gemmer model 330 with stradle mounted bearing. It is
similar to Chrysler Airflow.. Remove the 4 screws on the
worm cover to take apart. Find an old Motors Manual to repair and adjust. See also Cord service bulleton 810 no. 22.
- BradC
15 Feb 2012 17:33 #22207
by BradC
How to separate the shaft from the steering box? was created by BradC
Can anyone tell me how to remove the steering (column) shaft from the steering box on my '37 Westchester? The shaft has a collar a couple of inches from the box, with a spring between the collar and housing which holds a dust seal against the housing. I've moved the collar and spring assembly away from the steering box, and I don't see any kind of retaining mechanism, but the box seems to be rigidly attached to the shaft.
Brad
Brad
