Full flow oil filter mod
07 Aug 2011 00:13 #20680
by Tom Georgeson
Replied by Tom Georgeson on topic full flow oil filter
I used a liberal amount of Permatex threadlocker, the RED automotive grade, when I put in the allen headed set screw. I also ran a narrow punch down the bore and buggered the threads, it can't back out now. Good luck,you'll be glad you did this modification.
- charlesflick
05 Aug 2011 16:19 #20673
by charlesflick
Charles Flick
Replied by charlesflick on topic Full flow oil filter mod
Pat
Thanks for the info. Did you have a drawing of just the adapter for the machine shop or use the mod drawing. Any type of steel will work?
The mod drawing shows a triangle object at the end of the adapter. Is that just showing the end of the bit and how deep to drill?
The drawing doesn't show it but I would think the adapter should be long enough to enter the oil galley slightly and prevent the set screw from backing out. I know it is probably not needed but I like to be very safe.
Charles Flick
- Pat Leahy
- Thank you received: 28
05 Aug 2011 13:34 #20670
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic oil filter conversion
These are made from steel stock. I made (4) a few years ago and have used them up already. I think the machine shop charged me $25.00 each.
Pat Leahy
05 Aug 2011 05:32 #20668
by Tom Georgeson
Replied by Tom Georgeson on topic Full flow oil filter
Gail Shaw did mine and had the item you are refering to. You could call him to see if he has any left.
- charlesflick
04 Aug 2011 23:27 #20666
by charlesflick
Charles Flick
Full flow oil filter mod was created by charlesflick
I plan to do this mod but have a question. The drawing calls out a "3/8 NPT adapter" that is threaded into the block. Is this a standard part or custom made? From the look of the part, I was thinking of using brass 3/8 NPT to barbed hose adapter. Turning it down and threading the hose barb.
Any help, hints or guesses appreciated.
Charles Flick
