oil pressure
- rock
18 May 2011 11:48 #20093
by rock
Replied by rock on topic oil pressure
Mario i will try that i appreciate your reply thank you rock
- vaco
18 May 2011 09:32 #20090
by vaco
Replied by vaco on topic oil pressure
During some work on a Cord, I noted that some "sludge" collects at the entrance of the oil pressure line in to the oil pressure instrument/gauge. This may influence the reading. You have to take out the oil pressure gauge from the instr. panel and then once off the car also the fitting adapter to get it cleaned.
Mario
Mario
- rock
16 May 2011 17:58 #20078
by rock
oil pressure was created by rock
I nave noticed that my oil pressure reads 15 to 20lbs of pressure while running at 50 to 55 miles per hour and as low 5lbs after it is warn at idle any suggestions as to what the problem may be would be very much appreciated the car runs excellent thank you Rock
