Hubcap removal
- hportz
05 May 2011 07:08 #20010
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic hub cap removal
Dennis & Jim, The best removal tool that I have found is a carpenter's straight claw finishing hammer. Start opposite the valve stem. Place the round head end just in the cap hole enough to catch the cap, pad the claw
end to protect the rim, pry back the handle & work your way around & pop the cap off. This works. Henry
04 May 2011 23:28 #20001
by
Replied by on topic Hubcap removal
Hi Dennis,
The easiest way is to have freshly chromed hubcaps, remove the zip ties, polish them up real good, then go for a ride...one or two pot holes will pop them right off. <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
Seriously, the best way is with the "modern" hub cap removal tools NOT the originals. The ones most of us use "hook" the hub cap thru one of the holes and uses leverage off the tire to pop it off. If you don't have one of these tools try George A. he reproduces them.
Some hub caps are very hard to remove, I've found you just need to try different areas around the hub cap till it pops. If it's that hard you can bend the spring clips out a little to make it easier to remove the next time. But Keep the zip ties on when you're going down the road.
By the way are you still planning on joining us for the Cord Convoy?
- Dennis Jolicoeur
04 May 2011 16:31 #19996
by Dennis Jolicoeur
Dennis Jolicoeur
Hubcap removal was created by Dennis Jolicoeur
Is there any secret to removing Cord 810 hubcaps?
Dennis Jolicoeur
