Porsche valve adjusters
- ETHAN ALLEN TURNER
11 May 2011 15:30 #20041
by ETHAN ALLEN TURNER
Replied by ETHAN ALLEN TURNER on topic ROCKER SCREWS
The original rocker screws are the way to go and less expensive. Let me explain. The original screws that have been used for 75 years are worn flat. This then makes it hard to adjust properly. They need to be re-ground to meet factory specs. Once this is done adjusting the valves are a snap. Dan Ditullio does this service and I have been happy with the results. He has a post here about this service.
- hportz
05 May 2011 07:33 #20011
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Porsche valve adjusting screws
I believe that if you install Century Spring Co. spring #DD-79
(213-749-1466) on the adjusting screw to hold the foot up when
they are installed, the Porsche screws will work fine. I have them
in my engine.
in my engine.
27 Apr 2011 04:42 #19910
by Tom Georgeson
Replied by Tom Georgeson on topic valves
I too have talked to Gail Shaw and he said that he has had trouble with them. The problem is that if the engine back fires it can flip the little foot so that valves won't close. Then your engine is running on too few cylinders. You will have to pull the intake manifold to fix it. He doesn't recommend them for that very reason, I wouldn't use them.
27 Apr 2011 00:09 #19907
by Josh Malks
Replied by Josh Malks on topic Porsche valve adjusters
The elephant feet do not require redrilling of the rocker arm. The metric thread of the elephant foot adjuster is so close to the original's SAE thread that all it needs is the metric tap run thru it. Search for "Porsche valve adjusters" or similar on your ACD Archive DVD.
Those VW ball adjusters look interesting. Trouble is, no-one but the late Lee Richardson is ready to test them on his engine!
- charlesflick
20 Apr 2011 23:51 #19860
by charlesflick
Charles Flick
Replied by charlesflick on topic Porsche valve adjusters
when you do the elephant foot mod, I assume you drill and tap the Cord rockers to match the new adjusters.
There is an adjuster with an swivel ball that works like the elephant foot but without the pad.
www.b2600turbo.com/swivel%20foot.htm
Charles Flick
- dougklink
20 Apr 2011 12:07 #19857
by dougklink
Doug Klink
Estes Park, Colorado
812 S/C Phaeton
Replied by dougklink on topic Porsche valve adjuster
In talking with Gail Shaw last night, he said that he doesn't like them because if the car backfires the foot can get cocked keeping the valve open, then you have to pull the manifold to fix it. I'll pass.
Doug Klink
812 S/C Phaeton
- dougklink
17 Apr 2011 19:05 #19832
by dougklink
Doug Klink
812 S/C Phaeton
Adjuster is #901.105.370.02
Lock nut #999.034.005.00
Doug Klink
812 S/C Phaeton
- Red Fred
17 Apr 2011 16:02 #19829
by Red Fred
Life Member
Replied by Red Fred on topic elephant feet
The Porche elephant feet were installed in my engine some 10 years ago, when this modification was in fashion. I hear now that it's not the cat's meow anymore though? Could you give is the part number for "just in case".
Thanks, RF.
Thanks, RF.
Life Member
- dougklink
16 Apr 2011 15:05 #19822
by dougklink
Doug Klink
812 S/C Phaeton
Porsche valve adjusters was created by dougklink
I found the part number for the elephant foot valve adjusters and was going to order some but wondered how they are installed? I'm pretty sure the threads don't match up since the Porsche would be metric. Do the rocker arm holes have room to rethread or does it require the installation of inserts?
I'm assuming the benefit to using them is the rocker action of the foot keeping itself perpendicular to the valve stem?
Doug Klink
812 S/C Phaeton
