Resistor bar on the Top-Mount Regulator
- Aris Loumidis
14 Mar 2010 18:59 #16106
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Resistor bar on the Top-Mount Regulator
Thanks again, Tom !
Aris Loumidis
Athens, Greece
ACD Life Member
______________
14 Mar 2010 18:28 #16105
by Tom Georgeson
Replied by Tom Georgeson on topic generator bar
That is correct. It by passes the relay.
- Aris Loumidis
14 Mar 2010 14:11 #16104
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Thanks Tom, so when down it charges continiusly, correct?
Aris Loumidis
Athens, Greece
ACD Life Member
______________
12 Mar 2010 21:12 #16095
by Tom Georgeson
Replied by Tom Georgeson on topic Resistor bar
It is to allow the generator to charge all the time. It by passes the points in the box on top of the generator. It was suppose to be up in the summer and down in place in the winter.
- Aris Loumidis
11 Mar 2010 16:00 #16088
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Resistor bar on the Top-Mount Regulator was created by Aris Loumidis
Can someone please explain the function and especially the setting of the Resistor bar that is on the top-mount regulator?
Thanks!
Thanks!
Aris Loumidis
Athens, Greece
ACD Life Member
______________
