- Thank you received: 28
810 Rear Main Seal Help
- Pat Leahy
18 Jan 2010 13:21 #15594
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic rear main seal
There is no real rear main seal in this engine. Any oil that works past the babbit bearing falls in a groove in the bearing housing and out a brass tube into the pan. There should be a flat cork strip that covers the hump of the bearing housing and pan gasket. I use a gasket sealer called "Right Stuf" to seal. I install timing cover first, then the pan. Try to torque bolts equally and make sure the lip of the pan is flat. I surface this area with a belt sander to reveal high or low spot and correct with a hammer and dolly. I have more problem with the il level sender leaking than the pan.
Pat Leahy
- 36_810
18 Jan 2010 04:14 #15593
by 36_810
810 Rear Main Seal Help was created by 36_810
Need help with installation of rear main seal. My gasket set has a cork strip about 81/2in long but not sure how it works. There was no seal of any kind when I disassembled engine. Your help is much appreciated.
