Cord Transmission in Tucker?
- Laresmn
Paul Lares
1937 Cord Westchester
1937 Cord Custom Beverly SC
1937 Cord Phaeton SC
We had one for awhile that came with some story about it being one of the last Tuckers. The Tucker OQuinn had was number forty something.
All three had Cord transmissions, unless the Y-1 was identiccal to the Cord externally.
It could be that when these later cars were restored no Y-1 transmissions were availabe, and Cords were.
- tractiondk
The production model of the Tucker was meant to have an automatic transmission and Preston Tucker engaged a young engineer Allan Rice to develop it. While waiting for a working automatic transmission, they needed a manual transmission to make the prototypes drivable. Because they didn't have much time, they decided to use the Cord transmission. 22 Cord transmissions were found, but only 12 were actually used in the prototypes. Because of the problems with the Cord transmission, a more suitable manual transmission were developed, the Ypsilanti-1 (Y-1).
When the Y-1 became available they were used from number 1013. 3 of the Cord transmission already installed were later replaced with Y-1. when the automatic transmission was ready, it was going to replace all the Y-1.
Before the factory closed down only 3 automatic transmissions were made and tested. One is still in Tucker 1026.
After the close down the unfinished Tucker prototypes were sold and most of them were finished with leftover spare parts and the rest of the Cord transmissions.
Torsten Vig
Denmark
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- Ric Simpson
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
You could buy the alleged Tucker Convertible for about 5 million... Then you could get a look-see.
- Ric Simpson
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
The last Tucker we took to a show I took the back seat out, removed the bulkhead and shifted the transmission by hand.
The Cord trans has a nuetral. The thing is, if it is parked in gear the engine has to be running to shift. I haven't encountered may lube problems, but low vacuum, or dirty vacuum cylinders will keep you parked.
- oldbanger71
Later they produced own gearboxes that looked almost the same safe beiing longer and having two synchonizer (one for fist and second, the other third and fourth ) Have a look in Josh Malks new book " Cord Complete " page 232 to read more details.
If anyone has corrections or additions, please do so <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- ASm73
www.laubly.com/1948tucker.htm
