Documentation on custom 1936 Cord
- dryesandno
i tend to agree with you....
except that rather than just open this door, i think the whole certification policy of the club should be reviewed in its entirety in order to clarify the process and what cars will be considered certifiable so that all members have no confusion about what will be acceptable and what will not.
but i don't know about following the CCCA lead....ha ha.
the CCCA board got into alot of hot water on the Chrysler issue. they approved the mark without going through the classification committee and without posting the idea in their newsletter and allowing for member comment.
the debate got so heated that the classification committee chair, an excellent person i must say, ended up deciding to resign his post over the controversy, as sadly, he was losing many long time friends on both sides of the issue.
the board had to rescind their approval, rerun the whole process etc etc. and eventually reapproved the Town & Country for acceptance, but not without alot of controversy over the process.
the board was widely split on the decision and the club had to do alot of sole searching to determine where exactly it was headed when it opened up this little door......and let a 1948 production car into the fold.
its only a few years from 1948 to the 1950's. fortunately or not, our club won't have to worry about deciding whether to accept more modern cars.
but i think this issue about what is certifiable and what is not should be dealt with in a comprehensive way by the board.
i do appreciate there is an existing policy and some might say there is no need for change.
but as time passes the orginality of the cars seems to becoming more and more important. owners are looking to the clubs for assistance in this area. and with a finite number of cars and growing interest, the boundaries on what is acceptable are being pushed further.
in light of this, the policy needs to be reassessed every few years if only to ensure our club remains up to date with the needs of its members and the reality of the world we are in. this does not necessarily mean we need to change. we just need to ensure that nothing has changed that would require any change.....
the plan on what to accept and what not to accept should be published in the newsletter for comment. those comments should be taken into consideration. and then an updated club policy should be published by the board and reviewed every 5 to 7 years.
anyone deciding to get a car certified should be asked to sign off that they agree with the board policy prior to the certification taking place....so we protect our legal butt....unfortunately a necessary evil in this day and age.
and any cars that don't fit the updated policy but were previously certified under the old rules should be grandfathered and this fact should also be communicated to members and should also be acknowledged by those applying for certification, so that they can't use these old examples for any legal argument they might put forth as to why their car should be certified when these were grandfathered.
no doubt its a tricky area. but it needs to be dealt with.
i have provided my two cents as to what i think the certification policy should be elsewhere in this forum....but i am only one member and so my ideas don't carry much weight. they are just food for thought.
brent
- Mike Brady
- Thank you received: 19
The top and glass could have been obtained during the time frame of production.
The changes are bolt on, not changing any body panels.
Would incorrect year bolt on changes, hubcaps or heater body, drive upgrades, affect acceptance?
It could be argued the original key blank was not used.
Would the rules be bent for accessories like radial tires on original rims?
- West Peterson
I agree with your opinion. However, because Derham was still in business well into the 1950s, it's very possible that it could have been done by Derham [i:2fgi5ffl]after[/i:2fgi5ffl] WWII. Would that put it in the same kettle of fish with Karl's Kustom Koach?
I believe that a new body or customization done by a recognized coachbuilder makes a car certifiable. The Labourdette Auburn is an example. Many L-29s carried custom bodies. Some Duesenbergs had their original bodies modified by Bohman & Schwartz. If documentation can be found to show that this Cord was modified by Derham, then that's step one.
The second issue is stickier. If a car was modified during the factory era, or at least before WWII, I can see that as acceptable. If the exact same work was done by Karl's Kustom Koach in the 1960s, that's a whole 'nother kettle of fish. Then it is no different than the Auburn with the Camaro roof, recently discussed.
The market will determine what this car's value is. But unless it meets the tests of "who" and "when" I do not believe that the ACD Club should lend its imprimatur to it.
- dryesandno
perhaps you mean to use the words "original" before the words "body style, chassis, engine and drivetrain".
but then again, many cars have been certified without original engines, even going so far i believe as to certify 1936 cars with supercharged engines, something you couldn't get from the factory....in 1936.
could you elaborate on your thoughts here?
this car has definitely had its top modified such that it no longer represents what an original car from the factory would have looked like.
are you suggesting that this car can be certified when it has a modified top/body from factory original.
yet my auburn 12 speedster, which has a correct original speedster body, correct 12 frame, correct 12 engine and correct 12 drivetrain (just from two different cars) was not certified by the board?
i didn't think the current policy would allow a car that has had its body, or top in this case, modified from original to be certified when no such car ever came from the factory. i think if this happened that it would be a change to the current policy, as far as it has been explained to me......
i was told non-factory bodies were only allowed on duesenbergs as they all came with custom bodies....but all other cars must have the body that came from the factory.
this would be opening up a new window.......wouldn't it?
right now, i don't think any body modification from factory specs is acceptable. once you allow some modification, where do you end with that thought?
let me know if the club plans to do this and i will bring my speedster back for another go at certification.....as my body has never been modified and is a factory original speedster body.
surely a car with a factory original body (identical for 8 and 12 speedsters), all of the parts of which did come from the factory, albeit switched from an 8 to a 12 frame, should be allowed to be certified before we start opening up the process to bodies/tops that have been modified from the factory specs.
thanks
brent
ps. personally i think the car should be eligible for certification, but if the board is going to apply their policies consistently to all members, i don't think this car would qualify under the current policies.
- dryesandno
But I'm having trouble picturing the elegant lady gracefully getting out of the back seat.
That said, it definitely has the look of a custom body builder who has worked with classics. Derham is a good guess. Note how the flat windshield lends a formal look that goes beautifully with the deville top, landau irons and tiny rear window. You can almost see the chauffeur pulling up to the country club.
- Bill Hummel
Black on black on black. One of my favorite colors!
Is it for sale?
- Mike Brady
CORDially, Mike
- West Peterson
Thank you for your response.
I don't think this is a "sore subject" especially compared to some of the others that are posted on the site. I think it's always interested in seeing these cars.
This car is known around the club. The car was customized by Derham but I don't know when, if it wasn't when the car was new it was probably right after the war, but that's only a guess.
From the photos it looks like a very nice car. I can't tell from the photos but the rear section of the top looks like it's solid.
Maybe there's someone else out there who could provide some more info on this car.
- West Peterson
- curt
- West Peterson
