VIN NUMBER 810/812
- oldbanger71
17 Aug 2009 21:19 #14241
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic VIN NUMBER 810/812
Hi Brutus, the VIN should be found on a tag plate that is mounted on the right side of the cowl where serial- and enginenumber is stamped.
On the right side of each stub frames is very lightley stamped 3 digit chassis number plus 1000 to rach 4 digits plus a letter; do not sandblast or scrape the area between the two rivets as it could resault in loss of the framenumbers, a single coat of paint could obsure it.
Engine Number is found on engineblock-casting first mountinglug for bellhousing lefthandside waterpump tube to radiator.
Best is to get membership of ACD-club for best support as your questions are basic and more challaging questions will comme up while mentaining this car
<!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- Brutus
17 Aug 2009 20:09 #14237
by Brutus
VIN NUMBER 810/812 was created by Brutus
Hello folks, A client of mine just bought a 1937 Cord and I'm having a hard time to find the location of the VIN number to transfer the documents. Please, any help will be appreciated. One more thing, does the engine has a number identification? Where it would be?
Thank you guys very much.
Best regards from Brazil.
