Attaching hood lacing
- stroker
26 May 2009 01:25 #13601
by stroker
Replied by stroker on topic Attaching hood lacing
Gents- Thanks for the info! I'm on it. Yep, this is a really GOOD club!
Pete
Pete
- hportz
24 May 2009 06:30 #13584
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Attaching hood lacing
Pete, Originally it was fastened either of two ways. Early cars the factory used drive nails (like were used for the windlace & carpet in some places). Later ones used slotted binding head sheet metal screws. You can tell wich were used by the holes in the cowl; if the holes are indented in the metal, drive nails; if sheet metal screws were used the holes appear to be drilled. 31631H Henry
- oldbanger71
23 May 2009 19:18 #13580
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Attaching hood lacing
There are manny ways to overcome this, some ACD-members will twist my head for some proposal's :
1., but you can use ordenery poprivets, if you don't mind, orginality.
2. you can ask a trimmer to supplye brass or alu-rivets.
3. You find copper-nails with the right diameter in your hardwarestore, shorten them and procede as usual.
4. Ask a trimmer to do it.
I hope this was of some help, and only if for finding out, what you don't want. <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- stroker
23 May 2009 18:57 #13578
by stroker
Attaching hood lacing was created by stroker
Gents- I'm having a devil of a time attaching the hood lacing on 2241H. I have 1/8" split rivets about 9/16" long which I push thru the webbing, leaving about 7/16" blades sticking out below. I can't seem to be able to bend these suckers over with needle nose pliers- too stiff. Can't locate brass rivets anywhere, so what's this guy gonna do?
Any help will be most appreciated!
Pete Rhoads,somewhere under 32241H.
BTW, she runs and shifts Great!! Fast little sucker. Now to get the front fenders done and the interior finished.
