Window Glass Question
14 May 2009 05:19 #13481
by Tom Georgeson
Replied by Tom Georgeson on topic window glass
The lock is not in the way. I think that the glass was just cut shorter for one door, it was probaly a replacement glass. I put the same size windows in the front doors of my Westchester a couple of years ago and no problems.
- Thank you received: 19
14 May 2009 01:11 #13480
by balinwire
Replied by balinwire on topic front door glass fitting
Hi Mike, Great instinct, possibly, will visually check the lock clearance next time door panel is off. My lock handle will be on the curb side on my car but it does not have the armrest seats so I can slide over to exit vehicle.
My window crank handles point to the rear when the windows are rolled up, 3 o- clock on copilots and at 9 on chauffeur's side.
- Mike Markin
14 May 2009 00:49 #13479
by Mike Markin
Replied by Mike Markin on topic Window Glass Question
Is it possible that the a door lock on one side might require a shorter window because of the lock tumbler?
13 May 2009 11:31 #13469
by balinwire
Replied by balinwire on topic odd shaped windows
The rear glass would have been the smaller ones so when they are lowered there would be a larger window opening as the wheel radius would interfere. The fronts were custom cut so it would be timed to the window lift and the window frame opening.
I will never forget my school teacher in the 6th grade telling us students about the old cars, he would say that they may be an inch different from front to rear. I could not understand that as all the cars were mass produced. He would say they were handbuilt. That measurement/tolerance, would apply to our cars.
<!-- s:cry: --><img src="{SMILIES_PATH}/icon_cry.gif" alt="" title="Crying or Very sad" /><!-- s:cry: --> The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the serviceman.
- MDMARKIN
13 May 2009 02:04 #13466
by MDMARKIN
Window Glass Question was created by MDMARKIN
I have 2 panes of front sedan window glass. One pane is 1 inch deeper at 15 5/8" than the other 14 5/8". The rear windows are 14" each. Any idea why the front glass is different between themselves? If correct, which goes on what side?
Mike Markin
Mike Markin
