Custom Beverly steeringcolumn longer than Westchester ?????
- oldbanger71
15 May 2009 07:42 #13501
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Custom Beverly steeringcolumn longer than Westchester ?????
Hi Henry, manny thanks for your help, do you have one left that you can sell to me ? I could trade it aginst my Westchester steeingcolumn.
Best regards Philipp <!-- s:shock: --><img src="{SMILIES_PATH}/icon_eek.gif" alt=":shock:" title="Shocked" /><!-- s:shock: -->
812 310 121 S
- hportz
15 May 2009 04:02 #13500
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Custom Bev
Philipp, The Custom Beverly steering shaft is 2 1/4" longer than the standard. This can be measured by removing the jacket tube (the housing around the shaft). The standard shaft would measure 49" from the set screw that holds the ring, spring & seal atop the steering box in place. The custom is 51 1/4". The overall length of each shaft is 6 1/2" longer. The jacket tube is 35 1/2" long (std is 33 1/2"). Picture #6 of your transmission shows the transmission oil filter & the mounting bracket for it are upside down & the "U" shaped clamp for it is missing. Henry
- oldbanger71
07 May 2009 21:15 #13442
by oldbanger71
812 310 121 S
Custom Beverly steeringcolumn longer than Westchester ????? was created by oldbanger71
<!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: --> <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: --> Is the original steering column of Custom Beverly longer than a standard Westchester ?
And if so how much longer is it ?
Maybe one of you who have a Custom Beverly could mesure his with a pic to explane which points he used a reference?
Any help whith this is gratley apprisiated, thanks in advanced. <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? --> <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? -->
812 310 121 S
