lycoming engine
26 Apr 2009 13:07 #13326
by Josh Malks
Replied by Josh Malks on topic lycoming engine
My first Cord had these on both sides. It's a plate to cover the holes in the sides where the block was broken by freezing. If carefully done it works.
JK Howell used to sell a cast repair plate with the petcock boss cast into it (and drilled and tapped.)
25 Apr 2009 15:08 #13322
by Tom_Parkinson
Replied by Tom_Parkinson on topic lycoming engine
I have not seen the like of what you are describing. Can you please post a pic for us?
22 Apr 2009 23:30 #13297
by
Replied by on topic plate
I'm sure it is a repair of the side of the engine. these engines had a bad problem with the sides of the engine and this is one of the many ways that was used to tried and fix. as long as it is not cracked internally and it does not leak externally it will be OK. Just not pretty.
K Clark
K Clark
- DAVIDS
22 Apr 2009 23:13 #13296
by DAVIDS
ACD Member
lycoming engine was created by DAVIDS
I have just received my 810 westchester for resto
and the engine has a plate on the RH side just below the head , its about 12 inches long and 6 inches wide ,Its bolted onto the block
Can someone tell me is this a modification or past problem?
ACD Member
