Radio hook up
- Mike Markin
- hportz
The foregoing was not well stated! The best part was that the yellow wire was taped off, that is correct! The other two wires in the cable are to be connected to the new speaker terminals (as Tom & Josh said). The wire braid is the shielding wire for the cable, grounding this may help eliminate interference ? Henryhportz wrote: Mike, I'll quote from ACD news letter 2003 # 5. All electrodynamic speakers use 3 wires. Standard color code for these wires is yellow for the field coil, green for the voice coil, & black, brown, or bare braid wire for the ground. A permanent magnet speaker only requires the voice coil & ground. To replace your old speaker with a new one, simply tape off & don't use the yellow wire(REMEMBER it is connected directly to your HOT wire, & will make SPARKS & SMOKE if allowed to touch ANYTHING!). Connect the voice coil & ground wire to the new speaker terminals. Dan Schultz & Randy Ema did this article. OK? Henry
www.portzcordz.com (photos)
- Mike Markin
- hportz
- Mike Markin
