- Thank you received: 25
Oil Pump Drive Shaft ?
- E L
04 Feb 2009 12:04 #12630
by E L
Replied by E L on topic Oil Pump Drive Shaft ?
You are on track. The carrier and the shaft are an assembly and will push from the bottom. Cam shaft must be removed first.
- dartsmart67
04 Feb 2009 04:13 #12627
by dartsmart67
ACD Club Member
Oil Pump Drive Shaft ? was created by dartsmart67
Please advise. Had to drill out shaft set screw but still not sure how shaft removes. I understand it removes from top but it looks like square drive collar at the crankcase end would prevent this. Is there a pin or something that holds that in place or am I way off track thanks.
ACD Club Member
