Again Cord-parts to identfy for my '37 CCBBC
- oldbanger71
29 Apr 2009 22:02 #13370
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Again Cord-parts to identfy for my '37 CCBBC
Thanks Tom for breitening up my fog and confusion about speedogear <!-- s:oops: --><img src="{SMILIES_PATH}/icon_redface.gif" alt=":oops:" title="Embarassed" /><!-- s:oops: -->
812 310 121 S
29 Apr 2009 16:33 #13368
by Tom Georgeson
Replied by Tom Georgeson on topic Speedometer cable
The speedometer one fits in the right side of the transmission oil pump. The other fits in the housing attached to the timing cover off the nose of the crankshaft.
- oldbanger71
29 Apr 2009 09:43 #13362
by oldbanger71
812 310 121 S
Hi Tom so they are located on different places; the one fitted to the timingchaincover is which one , tachometer? Is the other fitted to the transmission somewhere , speedometer?
best regards and thanks for your help.
812 310 121 S
03 Jan 2009 19:47 #12350
by Tom_Parkinson
Replied by Tom_Parkinson on topic fiber gear
Hi,
On my '37 non-supercharged Westchester renumbered-from-a-36 Cord, the fiber gear is for the tachometer. The speedometer gear is metal on my car.
- oldbanger71
17 Dec 2008 22:08 #12271
by oldbanger71
812 310 121 S
Again Cord-parts to identfy for my '37 CCBBC was created by oldbanger71
Hello out there, here i'm agin with some parts to identify, they came with my '37 CCBBC.
Speedo-drive-bushing for SC timingcover ?
Speedo-drive with fibre-tooth-wheel, Number in shaft says: SV 92102
Gearbox frontcase numbers ( B 60 728 )
Gearbox-main-case Number
Gearbox
Shiftmechanisme maincylinder ??
Your help in identifying these parts will help me very much.
By the way CCBBC is the short for " Cord Custom Beverly Basket Case " <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
Gearbox
812 310 121 S
