Cord-parts to identify please.
- hportz
10 Dec 2008 02:15 #12190
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Cord-parts to identify please.
Philipp , I should have pointed out that item 5 is able to to be adjusted so that you can time the distributor correctly without bothering to time the intermediate drive assembly in any particulary way with the cam shaft gear. If you look down in the large end you will see a slotted screw there. Hold the assembly in a vise by the shaft ,lossen the screw then the vise slightly, with the large diameter resting on the vise & screw driver in slot tap the driver handle downward with a hamer blow ; this will lossen the lower shaft from the upper large diameter. You can now rotate the upper part on the lower shaft . You can now rotate the two parts independitly to time the distributor as required . Retighten the screw. OK ? Henry
- oldbanger71
09 Dec 2008 10:51 #12174
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Cord-parts to identify please.
Hi Henry, many thanks for your asistance, it's very helpful and your answer came much faster than i could hope for.
Cordially, Philipp
Cordially, Philipp
812 310 121 S
- hportz
09 Dec 2008 06:01 #12173
by hportz
Philipp, 1.Not Cord recommended heater & 28 amp Shunt generator. 2&3 S/C TC cover . 4 Std eng top mount fuel pump drive . 5 Intermediate distr. drive ( S/C or std.) . 6 Hd light bucket shaft bkt . 7 Distributor to intake manifold mtg. bracket . 8 Outer U-J bell bushing (Bendix). 9 Not Cord master cylinder . 10 Suspension bumper mounting bracket . 11 Water pump drive pulley. OK?
- oldbanger71
08 Dec 2008 19:16 #12164
by oldbanger71
812 310 121 S
Cord-parts to identify please. was created by oldbanger71
Here are some parts from my basket case Custom Beverly.
Can somebody shed some light on what they are, if they're correct for 1937 and if SC or standard ?
many thanks for your help in advanced.
812 310 121 S
