Timing-chain
- hportz
05 Dec 2008 22:57 #12098
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Timing-chain
Philipp, Two questions you asked not answered. Lift of the cam lobes is the same however they do have different valve timing & dwell ( not obvious). There is no difference between S/C cylinder heads & standard cylinder heads.The upholstery in your car appears to be original . 31361F Henry
05 Dec 2008 16:50 #12091
by Josh Malks
Replied by Josh Malks on topic Timing-chain
810s had a rectangular handle as yours does. 812s had a small round key lock, no handle. Understand that there were occasional exceptions to every Cord standard. They may just have had a set of 810 doors sitting around. Or, the buyer may have requested them. Or, someone may have switched them in the past 70+ years.
- oldbanger71
05 Dec 2008 15:38 #12085
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Timing-chain
Josh, what's the difference ? and What would that implye ? The body has a bustleback no tags but was palmbeachtan outside and inside some sort of burgundy very fine grain metalflake, upholstery is burgundy fabric too
812 310 121 S
05 Dec 2008 15:34 #12084
by Josh Malks
This car has 810 glove box doors.
- oldbanger71
05 Dec 2008 15:15 #12083
by oldbanger71
812 310 121 S
If there is a SC-timingchain fitted to the engine, could one conclude that with that beeing a fact, there is also a SC-camshaft mounted in the engine ?
As one would think if the chain and camtimingwheel is wider, the camshaft would be longer too, right ?
Are the lobes of the camshaft higher or wider on the peak than standard ?
How can the SC-heads be identified from the standard heads ?
Anyhow, i aprisiate your technical knowledge, sharing with me and other intrested fellow club members. <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
812 310 121 S
- E L
- Thank you received: 25
05 Dec 2008 14:38 #12081
by E L
Replied by E L on topic Timing-chain
Henry, I never like making suggestions to senior scholars of Cord, however I think that the s/c chain is .500 inches wider then std. making it 1.750 in width
- hportz
05 Dec 2008 03:39 #12072
by hportz
Philipp, I can't answer all your questions exactly because I didn't take the time to measure each part , but this should sufice . The standard t/c is 1.25 " wide & the cover is a steel stamping with a cast iron tach adapter bolted to it . The S/C t/c cover is an aluminum casting (a picture exists showing a stamped housing but I have never seen a real stamped steel one in 60 years of Cords) .The S/C t/c is about .250 " wider than the standard engine t/c . You have a big restoration ahead of you ! 31631F Henry
- oldbanger71
02 Dec 2008 00:06 #12015
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Newley bought '37 Custom Beverly
That's my new '37 Cord Custom Berverly sc , originaly Palmbeachtan outside/ burgundy inside
<!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
812 310 121 S
- oldbanger71
01 Dec 2008 23:01 #12014
by oldbanger71
812 310 121 S
Timing-chain was created by oldbanger71
Hi out there, i'm about to identifie some of the parts i've got with my Custom Beverly i bought latley and picked up last week in Switzerland.
What is the width of a standard timing-chain compared to a supercharged one ?
What is the deepness of the timingchain-cover compared to standard and supercharged ?
Any numbers to identifie ?
Many thanks in advanced for your help. <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? -->
812 310 121 S
