- Thank you received: 28
812 Carburetor Flooding
- Pat Leahy
27 May 2008 11:54 #10213
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Flooding
From my experiences, you need to make sure you are below 6 PSI fuel pressure. I use a NAPA in line fuel pump (Rotary w/filter) rated at 2-4 PSI. The other main concern is a leaking carb float. Many times they seem OK but eventually fill partial with gas and will no longer keep proper level.
Pat Leahy
- pkschafer
19 May 2008 23:56 #10135
by pkschafer
812 Carburetor Flooding was created by pkschafer
My812 non supercharged cord tends to flood easily. Especially when hot. It presently has mechanical fuel pump w/o in line fuel pressure regulator. I believe the carb was recently rebuilt.
