812 Cord Auxillary fan and Cooling
- Bill McLaughlin
My question is, when driving without this fan on, will it inhibit airflow to the radiator because the blades are stationary, in-front of the radiator ?
Bill McLaughlin
Cord 812 Westchester
- hportz
www.portzcordz.com (photos)
1. Does anyone know of a source for SIX-volt auxiliary radiator fans?
2. Since my Cord is--(still!)--disassembled, this would be a good time to make and install a radiator shroud. Looks like I'll be having a conversation with my sheet metal foreman.
- vaco
cgi.ebay.com/ebaymotors/Cord-812 ... .m14.l1308
has a shroud (two of the available pictures show it). The colour of the car is certainly not my favorite. Mario
- hportz
And I'm still hoping to see a photo of peter812's shroud.
- john mccall
- Thank you received: 34
- peter812
- Wes Trail
As for the pressure in the cooling system, I have no clue what the original caps had as far as pressure. The idea there is to have a higher pressure than atmosphere to increase the boiling point of water. Coolant is also designed to help raise the boiling point depending on the mix ratio, will change by something like 20 degrees. By raising the boiling point, it means that the engine can get hotter before it boils the coolant out. Something else I run, that I don't know if Cords had, were coolant recovery tanks. They allow the fluid to expand into them as it gets hot then it will pull it back into the engine as the system cools down (this just keeps from having to re-fill it every time it gets hot and loses fluid)
- pkschafer
