Front fender mount- 812 Custom Beverly
- hportz
21 Apr 2008 00:09 #9905
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic fender attach
Garry, they both should be on top. 31631F Henry
- GarryMorgan
20 Apr 2008 20:32 #9901
by GarryMorgan
1937 812 Sidemount Custom Beverly
Front fender mount- 812 Custom Beverly was created by GarryMorgan
Fellow Cord nuts- I need some feedback on a hopefully simple problem. I noticed that my sidemount 812 Beverly seemed to be drooping to one side. When I did a level check, one fender is a full 3/4 inch lower than the other--Not a weight issue- the sidemount car has an extra bracket under the well. I noticed that one one side the fender bracket (attached to the edge of the wheel opening) sits on top of the antler like bracket coming from the frame while on the other side it is attached under. Solution seems simple but could someone peek under and tell me which fender to remove and remount? Thanks in advance
Garry Morgan
812 Custom Beverly Sidemount
Garry Morgan
