manual transmission drift?
23 Feb 2008 21:18 #9565
by Tom Georgeson
Replied by Tom Georgeson on topic Tire truning
As I'm sure you know. Don't run you car out of gear for very long with the clutch not depressed. It does not have the gear pump turning and putting oil to the gears.
- E L
- Thank you received: 25
22 Feb 2008 00:49 #9551
by E L
Replied by E L on topic manual transmission drift?
Relax, everything is normal. If they don't move then I would be worried. The thick lube between the gears and the sleeve shaft is enough to drive the gears with no load on them.
- Eldee
21 Feb 2008 23:28 #9547
by Eldee
manual transmission drift? was created by Eldee
I have my 810 up on jack stands. While the car is running and in neutral the wheels turn slowly and can be stopped with a finger. It is my understanding that while in neutral there should be nothing causing the wheels to turn. Is it possible that something is out of adjustment?
