Radial Tires Size
- Sebrings
10 Apr 2009 01:49 #13156
by Sebrings
Replied by Sebrings on topic Radial Tires Size
I had clearance problems with the 215/16s I got from White Wall Candy store and ended up replacing them with 205/16s. They look fine and give enough clearance to not rub on the back fenders.
- Scotty
22 Feb 2008 05:53 #9554
by Scotty
Replied by Scotty on topic Radial Tires Size
I am using Coker 6.50RX16 whitewalls on my car. They fit fine, but do look a little skinny. Other than that they seem to work OK.
- vaco
19 Feb 2008 18:07 #9545
by vaco
Radial Tires Size was created by vaco
Is anyone using the Universal 650R16 (3-1/4) whitewall tires on their Cord? Or are all(?) using 215/75/16 from Diamond Back Classic (as addressed in Josh's article in the Newsletter 3/2003 and posts in 2004). Is anyone using another size of radials (due to clearance problems?)
Thanks Mario
Thanks Mario
