torque specs
06 Feb 2008 13:51 #9437
Replied by mikespeed35 on topic torque specs
Of course you don't torque a dry thread. Use oil, not ARP lub.
05 Feb 2008 00:35 #9418
by balinwire
Replied by balinwire on topic bolt stretch
Hi, I scoured many printed pages looking for spec's for acd torque settings, nothing. It is sort of a black art. I cant imagine setting a dry thread but maybe a brake part. There is a soft touch needed, don't go to far or strip threads, no stretch and off comes the rod.
There are lots of bolt setting charts on-line to download and print,
www.futek.com/boltcalc.aspx
www.engineershandbook.com/Tables/torque.htm
www.raskcycle.com/techtip/webdoc14.html
www.engineersedge.com/torque_table_sae.htm
www.boltscience.com/pages/quality.htm
www.sizes.com/tools/bolts_SAEtork.htm
p-car.com/torque/
p-car.com/torque/
- sharknose1
03 Feb 2008 04:39 #9398
by sharknose1
Replied by sharknose1 on topic torque specs
Thank you for the info and your quick replies.
03 Feb 2008 04:09 #9397
I will caution anyone when torquing fasteners. ARP makes a special lub to use when torquing fasteners. Don't use it unless you are using there special hardened fasteners. If you use it on reg. fasteners they will twist right off before the torque spec. are reached.
03 Feb 2008 03:51 #9396
by Tom Georgeson
Replied by Tom Georgeson on topic torque on bolts
My information was gleemed from others who I consider experts. The torquing was done with clean oiled threads. I used these settings and all is well.
Rods at 35/40 lbs.
Mains at 90 lbs.
Heads at 55 lbs.
Good luck
Rods at 35/40 lbs.
Mains at 90 lbs.
Heads at 55 lbs.
Good luck
- sharknose1
02 Feb 2008 21:33 #9394
by sharknose1
torque specs was created by sharknose1
I am in the process of restoring a 37 Westchester and the engine work has begun. I need to know what the connecting rod bolts and main caps are required to be torqued to. I can't find this in any information that I have. Any help would be great.Thank you in advance. Brian
