Oil level questions
- cbsIII
18 Dec 2007 00:46 #8941
by cbsIII
"I work for the Auburn Automobile Company. I am not an automobile race car driver although I hold more world speed records than any other man in the world" -Ab Jenkins 1937
Replied by cbsIII on topic Oil level questions
Do entrants have to reinstall National Rawhide leather grease seals to qualify original drivetrain?
17 Dec 2007 03:25 #8931
Replied by mikespeed35 on topic Oil level questions
Josh. In 2009 you won't have to wait any longer. I know of at least one L-29 that is making the trip,out and back! Any other ACD member with a ACD car, with original drivetrain, is invited. More info.will be forthcoming this summer.
We are even inviting the OTHER CORDS.
- Ray Parker
16 Dec 2007 00:25 #8921
by Ray Parker
Replied by Ray Parker on topic Oil level questions
Mike You are a Dip Stick!!!
- JOEL GIVNER
15 Dec 2007 12:58 #8917
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic Oil level questions
THE L29 OWNERS DON'T HAVE ENOUGH RETIREMENT TIME LEFT FOR THE DURATION OF THE CROSS COUNTRY TRIP
JEG
15 Dec 2007 07:35 #8916
by Josh Malks
Replied by Josh Malks on topic Oil level questions
The last time four L-29s crossed the country was in April 1929. The last time four 810/812s did it was 2007. We're waiting. <!-- s8) --><img src="{SMILIES_PATH}/icon_cool.gif" alt="" title="Cool" /><!-- s8) -->
15 Dec 2007 05:51 #8915
Be careful when you put that dipstick in the transmission. Those 810/12 tyranny's are pretty fragile and the dipstick might break them.
14 Dec 2007 21:49 #8910
by Josh Malks
Remove the tranny fill plug and drop the oil dipstick into the hole. NOTE: It may take several tries, since the stick has to slide past the shift rails just right. The stick must fall in of its own weight --- do not push it down. The original factory full mark on the dipstick is the correct level for the tranny fluid. (This works only with the original dipstick, or one with the dimple in the same location.)
- Russell Colman
14 Dec 2007 21:22 #8909
by Russell Colman
Replied by Russell Colman on topic Oil level questions
Thanks Josh.
As usual, most helpful.
Any thoughts on the transmission oil level question?
14 Dec 2007 16:01 #8907
by Josh Malks
The Cord V-8 takes [u:3owgxa0p]eight[/u:3owgxa0p] quarts of oil, not seven as indicated in the Owner's Manual. The original dipstick has a mark at about 6 1/8" from the stop at the top, indicating full. A punch mark at about 5 3/4" is correct. Best way to do this, next time you change your oil, is to put in 8 quarts, check the level after a while, then punch the dipstick at that level.
- Russell Colman
14 Dec 2007 09:26 #8903
by Russell Colman
Oil level questions was created by Russell Colman
One of the few non-original items on my standard Cord 812 Phaeton appears to be the dipstick for the engine oil sump.
Result is I've never known exactly what level to keep the engine oil at.
If someone has an original dipstick, would they mind measuring the length from the stop-point at the top of the dipstick to the oil indicator marks on the stick, and letting me know how far down the stick the correct oil level markings should be?
I'm assuming there would be a max and min level mark?
It's a standard FB engine - not sure if this makes any difference.
Also, I've been told that the same dipstick marking/s can be used to check the transmission oil level when the filler plug is out. Is this correct?
Regards,
Russell Colman
Regards,
Russell Colman
