cat whiskers....window trim
Tom
- redfred
I've heard of a La Baron Bonney kit for the '37 Ford that is adaptable. Just don't know if it's a Tudor or Fordor, or if I'm to just order the doors, or?
RF.
I guess I wasn't clear enough. What you would be doing is cutting out new strips of cat whiskers from the mohair channel liner which you purchased to replace the existing ones. You don't even have to take them off the doors or moldings, just remove the old liner material and glue on the new. You might want to use a narrow point indelible black pen to finish off the edge of the existing molding around the window openings.
The item you need to purchase is in Restoation Specialties Supply's catalog as Part number G 100. Just cut long narrow strips of the cat whiskers from the mohair liner and glue in place. I used Goop to glue mine. It was a lot easier than bending new ones which I had to do for a couple.
If I haven't made it clear give me a call.
Tom
- Jack Richard
Jack
Jack Richard, D.D.S.
- redfred
Whoever put the catalog on the site, thanks you.
Tom
- acdclubadmin
- New Forum User
Tom
- redfred
Thanks for the lead on the channels, but it's the flat felts that are in the shape of the window that I'm after at this time.
Many thanks, RF.
If you don't have their catalog you can call them at 814-467-9842 or 814-467-5323. Their address is P.O. Box 328, Windber, PA 15963. They also have other stuff like screws, bolts, etc.
Tom
- redfred
Many thanks, RF.
Tom Georgeson
- redfred
Windowless in Winter, RF.
