AC fuel pump parts
06 Nov 2007 18:25 #8610
Replied by mikespeed35 on topic Fuel Pump
I called Hanna Rubber and was told their dia. material was resistant to oil, fuel, but didn't know about alcohol. It has a nitrile binder which is what buna-n is. Buna-n does not do well with fuel in O rings. They also didn't seem to know about it being used for fuel pump dia. Did I get the wrong sales person or what?
01 Nov 2007 14:07 #8568
by Josh Malks
Replied by Josh Malks on topic AC fuel pump parts
This is such a great example of how these Forums benefit us all. Guy #1 asks a question. #2 answers it. #3 asks a follow-up question. #4 answers it. All within two days. What a club!
- JOEL GIVNER
01 Nov 2007 13:16 #8567
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic AC fuel pump parts
Hanna Rubber Company
1511 Baltimore
Kansas City, MO 64108-1301
816.221.9600
800.591.3035
816.421.0583 FAX
1511 Baltimore
816.221.9600
800.591.3035
816.421.0583 FAX
JEG
01 Nov 2007 03:36 #8559
Replied by mikespeed35 on topic AC fuel pump parts
Do you have a phone no. for Hanna Bob?
- R Coleman
31 Oct 2007 13:11 #8547
by R Coleman
Bob
810 2350H
812 31649S
Replied by R Coleman on topic AC fuel pump parts
On several occasions, I have made the diaphragm--quite simple. Remove the 10 screws around the top of the pump and remove the old diaphragm to use as a pattern. Can be done either with pump on car or removed. The later is easier for the central piston is in neutral position. Punch holes with leather punch. Pump diaphragm material can be obtained from Hanna Rubber in Kansas City. The newer material is impervious to the deleterious effects of ethanol. While you are at it, make a spare as back-up.
Bob
810 2350H
812 31649S
- pilotc90a
30 Oct 2007 18:23 #8542
by pilotc90a
AC fuel pump parts was created by pilotc90a
I have an AC model "D" fuel pump for a 812 custom Beverly, just like the one in the book (Cord owners companion). I need to replace the diaphragm. I have been told there is a number stamped on the flange where it mounts to the engine, but the pump had been resurfaced at some point and there is no number anywhere on the pump. Can anyone tell me where I can get a new diaphragm, a number for the pump, or a substitute material so I can make my own? There is a shop I found on the Internet, but they won?t even talk t me without the number!
