A little help in Portland needed, please.
Incidentally, as the moderator of this forum, may I respectfully make a small plea to all who read this to have the topic of future new threads reflect the subject. In this case, for example, "Help Needed In Portland" does not describe what the thread is about. Thanks!
- Jack Richard
Jack
Jack Richard, D.D.S.
Tom Georgeson
- Ric Simpson
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
- Ric Simpson
Josh. I didn't think on an 810/812 the engine would restart after stalling, unless the clutch was depressed??
All the best, Ric.
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
- Randy in Portland
First Round, First Minute....Muhammad Ali
The real reason that I stopped using the Startix was that it won't work with an alternator without special modifications. Just got lazy, I guess. And note that I only suggested the alternative to those who "worry". But I do have an original Startix squirreled away for when I get ready to do it properly.
- E L
- Thank you received: 25
Since your Cord has been improved like mine--ie, Startix is long gone--repairs consisting of replacing the solenoid is easy AND inexpensive!
---Tom
It sound like the solinoid is stuck. Disconnect the battery cable from the solinoid and try checking the continuity between the batery terminal and the starter terminal. If there is continuity the solinoid is stuck. Try rapping it with the handle of a screw driver to unstick it. It might free itself just from disconnecting the cable.
Don't worry if the problem disappears without you figuring out what's wrong...it will show up again.
- hportz
www.portzcordz.com (photos)
- Randy in Portland
