6 volt coil for the Cord 810-812
- Jazzman
19 Aug 2007 13:04 #7777
by Jazzman
I have heard there are 29,816 parts to one of these cords. Most of mine came ups..... and didn't fit
Replied by Jazzman on topic cord coil
AMEN
18 Aug 2007 13:46 #7768
by Josh Malks
Replied by Josh Malks on topic 6 volt coil for the Cord 810-812
Last comment. Don't use it to run your car with. Endless grief from NOS coils, whose shellac internal insulation has long since broken down. Gut it and use a modern coil under the dash, with wires poking out of the NOS coil.
- e merancy
18 Aug 2007 13:42 #7767
by e merancy
Replied by e merancy on topic coil
Pete. correct coil mount is also on ebay, number 320147750440 Ed.M.
e.merancy email
- e merancy
18 Aug 2007 13:35 #7766
by e merancy
Pete, I found mine on Ebay right now there is an after market coil available check out item number 150150758674 or keep looking on ebay for the autolite coil which was original equipment they do show up on occasion. Good Luck Ed.M.
e.merancy email
- stroker
18 Aug 2007 01:00 #7759
by stroker
6 volt coil for the Cord 810-812 was created by stroker
Gents; Can someone tell me where I can get a 6 volt coil for my Cord 810? As I understand there should be the high tension lead and the primary lead coming out the front and a couple of leads out the back for the ignition switch, which should be in an armored shroud.
Any help will be greatly appreciated!
Pete Rhoads
Pete Rhoads
