Water Tube
- mopar4ya
05 Apr 2007 01:21 #6766
by mopar4ya
Replied by mopar4ya on topic Water Tube
Thanks for the replies! I removed my water tubes by putting a rod through and driving out the soft plug. I did damage 1 of the tubes by doing this. If I had to do it again, I would try doing the vise grip method first. Oh well, live and learn So who sells the replacement tubes LOL!
Dan
Dan
04 Apr 2007 23:13 #6765
by Tom Georgeson
Replied by Tom Georgeson on topic water tubes
I pulled my tubes by prying up the edges and pulling them out with videgrips.
Before putting them back in I scraped the water passages of the block with a long screw driver and a piece of welding rod. I lifted the rust out with a magnetic on a flexible shaft. I got over 4 pounds of rust out of the block. I also put screens in the two outlet tubes.
Tom Georgeson
Tom Georgeson
04 Apr 2007 01:02 #6755
by Tom_Parkinson
Replied by Tom_Parkinson on topic Water Tube
There are water tubes....?
- Pat Leahy
- Thank you received: 27
02 Apr 2007 12:15 #6739
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Water Tubes
To remove, take a 36" piece of 1/2" round bar and slide it into the tube from the open end. Tap this until the the freeze plug comes out of the block on the other end. You can then tap it out the other end (will not fit through the freeze plug end). I have seldom found a bad one, just need a little cleaning. They are different lenghts, and have notches to line back up.
Pat Leahy
- Ric Simpson
02 Apr 2007 00:58 #6731
by Ric Simpson
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
Replied by Ric Simpson on topic Water Tube
Hi! I bought new tubes from Glen Pray back in the early '60s. The old ones came out surprisingly easy, and the new ones went in just as nicely. I'm not sure new ones were necessary, but as they were available, I put them in. Ric.
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
- mopar4ya
01 Apr 2007 18:14 #6725
by mopar4ya
Water Tube was created by mopar4ya
Can the water tubes through the block be removed and replaced without to much of a problem. And if so who has new ones?
Dan
Dan
