Transmission casing clearance
- hportz
21 Jan 2007 04:43 #6262
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic frame c'mbr
Russell, It occured to me that you may not have an origional c'mbr from the way you described it. The origional is a U shaped formed channel about 6" wide and about .125 thick. That really doesn't matter as long as it is a strong piece. Henry
- hportz
21 Jan 2007 04:26 #6261
by hportz
Replied by hportz on topic under radiator crossmember
Hi Russell, Any clearance should be OK ,it's usually a bit moore but that doesn't matter. Some guys even pad that area with rubber to try to stabilize the engine/trans mounting; feeling that this will help to eliminate shimmy. Henry
- Russell Colman
19 Jan 2007 11:55 #6237
by Russell Colman
Transmission casing clearance was created by Russell Colman
There's a steel plate cross-member bolted between the two main members of the sub-frame holding the front end together.
It sits just below the radiator and just above the transmission casing.
Can anyone tell me what a typical clearance should be between this cross-member and the transmission casing below it?
On my car it's currently only about 1/4". Is this enough?
Any advice appreciated.
Cheers
Cheers
