Advice on spark plugs
03 Jan 2007 00:58 #6081
by Josh Malks
Replied by Josh Malks on topic Advice on spark plugs
Sorry, Russell. My car is not handy and I don't write down the numbers. Any interchange book (at auto supply store) should be able to help.
- Russell Colman
02 Jan 2007 22:53 #6072
by Russell Colman
Replied by Russell Colman on topic Advice on spark plugs
Thanks again Josh.
Please tell me the number of the Autolite equivalent - I may need to use these if I can't find the Champion H10s.
Cheers
Russell
Cheers
Russell
02 Jan 2007 22:47 #6071
by Josh Malks
Dunno. I run a 6v Pertronix (many miles now) and the Autolite equivalent of Champ H-10s. (I use Autolite because they still blacken rather than cad plate the metal part, and I'm lazy.) Plugs still read OK --- don't seem to be too hot.
- Russell Colman
02 Jan 2007 21:29 #6070
by Russell Colman
Thanks Josh. Most helpful.
I'm about to install a 6V Pertronix ignition, which I assume will give better/hotter spark.
Do you think this would call for a cooler plug?
Regards
Russell
Regards
Russell
02 Jan 2007 14:49 #6068
by Josh Malks
The Cord came from the factory with Champion H-10 plugs.
- Russell Colman
02 Jan 2007 11:12 #6067
by Russell Colman
Advice on spark plugs was created by Russell Colman
I'd appreciate some advice on the best spark plugs for use in my 812 FB engine.
A quick search of forum postings showed some discussion mentioning Champion H8 (equiv RH8C) and Champion H10 (equiv RH10C) plugs. The 10 is a hotter plug than the 8.
Does heat range make a difference?
I currently have Bosch W8BC plugs in the car but these don't appear to be made any more.
Regards
Russell in the land of OZ
Regards
