Headlamps
All Cords, foibles and frailties notwithstanding, are real in this man's world.
<!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
You can park your Cord with the Real Cord's in the park. We allow any color!
Tom Georgeson
- Ric Simpson
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
- Wes Trail
On my dad's Cord replica, we use 12 volt lights (we found euro-style tail lamp bulbs from Autozone work well) behind the original instrument panel. The clock does not work, but could be powered in with the resistor as it only needs 6 volt power and is non specific on the source. The Amp meter is wired directly, as amps are amps no matter the voltage. The only other powered gage is the fuel/oil level gage, which I believe could be powered through the resistor as well.
It is just my opinion, but if you already have a working 12 volt system in place, I would probably leave it alone. The only reason my tractor was converted was it needed re-built anyway and 6 volt parts were not readily available. The Cord replica is already 12 volt, so we adapted both the instruments and the car to work together.
- Lee Titus
Don's # (541) 902-2255 .......Lee Titus
- oldbanger71
What i usually do is just put two 6 v batteries
and connect it serial. replace or rewind the generator for 12 v and ad a modern charger-relay then connect those things run with 12 v ( Generator, Headlamps, Cigar-lighter etc.like a 12v battery and others like the dashboard hook it only on one of both batteries ( 6 V ). The starter engine you can leave like it is, as it will turn a bit faster but can take the load. I'm not familiar up to now with the Starterix so get advise with someone who knows.
Best regards, Oldbanger71
812 310 121 S
- Bill Hummel
He took out the Lycoming engine and put in a Olds 455 V-8. At that time, everything was converted to 12-volt.
I am in the process of trying to undo a lot of these changes. The last thing I am going to do is to restore the engine compartment.
I am a new member, and as such, I am near the bottom of the food chain. Some of the older club members can probably shed some light on this.
However, I thought from Al Hatch's comments in the newsletter that ALL cars were welcome whether you had to push, pull, or drag it. Nearly all cars are works in progress, so my 2 cents says your car should be in the parade.
I hope to meet you in Auburn this year. You can look under the hood of my car at that time to see how they did my conversion.
Bill Hummel wrote: I have sealed beams in my Cabriolet. I dont recall that there was all that much to putting sealed beams in an 810.
I will try to take some pictures of how mine is set up. Maybe that will help you fabricate something.
I don't think it is that big a deal. (I am running 12-volts and Sylvania Halogens.) I can get the model # of the light for you as well.
Hi Bill,
I am interested in your 12-volt comment. While re-doing my 812 sedan, I have been considering converting to 12 volt. Questions: How did you deal with the generator/charging system and the instruments? I have considered putting a 12V battery in the trunk to run radiator fans, but have been stymied by the charging and instrument quetions.
Thakns for your comments on the site--they are always welcome.
Yours,
Tom
Tom Parkinson
- acdclubadmin
- New Forum User
If you want something like this, post a message in the NEWSLETTER section of this site.
I have learned so much from the few issues I have. There are so many interesting articles in every issue.
There could be a small donation to the club with every download.
- Auburn/Cord Parts
balinwire wrote: In the lens/reflector/bulb arrangment the lens is a seperate single piece.
Is there a part# and was this lens shared with any other vehicle?
My left one is cracked and has a different part no. from the right one. Is this lense available?
What is the correct diameter? 7" or 71/4? I am worried I will drop it during disasembly.
Any ideas before demolition, I will put a foam pad down under the fender so if the lense does fall it may survive.
<!-- s:arrow: --><img src="{SMILIES_PATH}/icon_arrow.gif" alt=":arrow:" title="Arrow" /><!-- s:arrow: --> This lense is not shared with any other vehicle.
Measures 7 23/32" to 7 3/4" O.D. 2 1/16" or 2 1/8" deep.
Cord part numbers:
K11144 is 2 1/16" deep or convex and has curved flutes.
K11224 is 2 1/8" deep or convex and has more or less all straight flutes
See ACD Newsleter No. 5 1991 for a good tech article on Cord headlamps.
<!-- s:!: --><img src="{SMILIES_PATH}/icon_exclaim.gif" alt=":!:" title="Exclamation" /><!-- s:!: --> Do not follow the factory service bulletin, you will destroy parts.
Stan
Auburn/Cord Parts, Inc. P.O. Box 547 1400 N. "A" St. Wellington, KS 67152 (620) 326-7751
When your headlamp lids are closed, nobody knows what you got in there, and at night who can see?
- jpsands
I know that with your help I will get those parts and the solution.
John Sands
619 298-1050 work
619 224-8558 home
- Auburn/Cord Parts
Please email us if you have a email address. I think we may have some parts for you. Are you looking for original type parts? If so, I can send you a couple pictures so we know exactly what you are looking for. If I don't hear from you we'll give you a call.
Auburn/Cord Parts
- Bill Hummel
- jpsands
John Sands
619 224-8558
