Al Goodman overdrive water pump pulley plans
- [email protected]
- Thank you received: 7
Henry Portz more efficient water pump impeller would be my choice.
- ACORDIAN
- [email protected]
- [email protected]
- Rileypu29
Thanks again.
Bill
Bill Kastanis
Bill the priblem with trying to clean out the block with the engine in the car is is getting the junk out of the block. you only have a small drain hole in the bottom of each side. some of the pieces that come off won't fit thru the hole. About the only way to to it with the engine in the car is to pull the heads and go down thru the cooling holes and vacuum the crap out.
There is a chance your radiator may be partially blocked. These engines have a tendancy to puke a bunch of junk into the radiator, especially if they have been sitting for a while. The best way to prevent this is to put screens in the radiator tubes onb top of the engine. Clean them once a year, more often if needed. You will be suprised at the amount of junk they collect. Also if the engine pukes the screens plug and you overheat quickly. Hut it's a quick fix to clean the screens instead of pulling the radiuator to have it boiled out.
Years ago I tried all the different fixes for overheating. Most of them had a small effect on overheating. The one fix that really helped was installing a fan shroud on the radiator. This eliminated the overheating in most cases. A cord will still overheat at prolonged slow speeds (such as a parade) or when you slow down after a high speed run.
- Rileypu29
I recently installed the Henry Portz water pump kit in the car so I don't suspect a pump issue. I will be pulling the radiator out for a good cleaning however it is one of the honeycomb styles and I am concerned about the lower flow of those radiators. Additionally the extremely thick core (4 inches) of the Cord radiators is not conducive to good air flow through the radiator. I also would like to clean out the engine cooling passages as best I can with the engine in the car. Does anyone have any recommendations as to the best way to do this? I don't know that the typical flush kits really do a good job of getting the junk out of the nooks and crannies in the block.
Thank you all for your help.
Bill
Bill Kastanis
- Rileypu29
Thank you.
Bill Kastanis
Bill Kastanis
