- Thank you received: 25
Clutch switch adjustment
- E L
Looking inside the switch, the sliding box has stops the allow this action.
- alsancle
- Thank you received: 16
E L wrote: The design of the original switch has a "delay" built in.
The position of disengage on the down stroke of the pedal is different then that of the up stroke. This gives the transmission more time to shift then it would if the switch was just a make or break type of switch.
Could you explain how this works? I'm wondering if maybe I don't understand something. My understanding is that when the clutch is depressed, the harness is energized by the red wire. When the clutch is released, then the power is dropped. I don't understand what the "delay" on the release would do.
- E L
- Pat Leahy
- Thank you received: 27
Pat Leahy
- alsancle
- wynlaidig
- Thank you received: 44
- alsancle
Is anyone making new reliable switches?
- alsancle
I'm very lucky that I live near Mike Lavalle of KES who restored the switch for me in 24 hours. According to him there were a number of issues:
1. The rivet on the hot input was loose and would flex losing contact.
2. The plate was cracked and also flexing.
3. The nubs that make contact were not even and were making uneven contact.
I put it in and all my starting problems were gone. Also my shift harness is now energized with the clutch down.
I was thrilled and jumped right in to testing the shifting with the new harness. It was not doing what it is supposed to do so more testing is in order. Sigh...
