- Thank you received: 8
Valve rotators
- Thomas Wilcock
06 Apr 2021 11:25 - 06 Apr 2021 11:27 #42853
by Thomas Wilcock
Replied by Thomas Wilcock on topic Valve rotators
Upon checking my old parts books I found that the only engine that used the VS 647 valve springs after 1960 was the GMC 637 V8 gasoline truck engine for the outer valve springs. It was listed in the Sealed Power parts book for the 1966-1972 engines. There must be modern easier to find components that will work. I will research it further.
Thomas
Thomas
Last edit: 06 Apr 2021 11:27 by Thomas Wilcock. Reason: overlooked one fact.
- Thomas Wilcock
04 Apr 2021 09:02 #42822
by Thomas Wilcock
Thank you for the information. It is a good start. I will post the information on the valve springs when I find it.
regards
Thomas
regards
Thomas
- Rileypu29
04 Apr 2021 03:37 #42821
by Rileypu29
Bill Kastanis
Replied by Rileypu29 on topic Valve rotators
Hi Tom,
I found an old Thompson part catalog online, see the below link. The RC-17A rotator looks to be Chrysler (page 24). I did not find the valve spring VS 647 in the catalog, maybe you will have better luck.
archive.org/details/ThompsonTradeCatalog...es/page/n23/mode/2up
Best regards,
Bill
Best regards,
Bill
Bill Kastanis
03 Apr 2021 20:58 - 03 Apr 2021 21:05 #42819
Replied by Terry Cockerell on topic Valve rotators
Hi Tom, the Actonite Cord has a set of those rotators on the exhaust valves.
The caps do have RC - 17 stamped on them and the valve springs are shorter that the standard springs to suit the deeper cap. The rotator is constructed with tiny bearing balls between the two pieces.
Attached are some pictures of the rotator cap and a standard Cord valve spring cap.
Sorry I have no idea where they originally came from.
Last edit: 03 Apr 2021 21:05 by Terry Cockerell. Reason: Adding pictures and revising text
- Thomas Wilcock
02 Apr 2021 12:46 #42807
by Thomas Wilcock
Valve rotators was created by Thomas Wilcock
In a 1954 ACD newsletter it was suggested to use valve rotators for the exhaust valves. It said that Thompson roto cap No. RC-17 used with valve spring # VS 647 work well. What vehicle were these originally used in and are there new part numbers because the old numbers do not turn up in searches?
Thomas
Thomas
