Thermostat
10 Jul 2020 23:36 #40496
Replied by Terry Cockerell on topic Thermostat
Gary, read around page 38 of Rudy's restoration.
09 Jul 2020 18:39 #40487
09 Jul 2020 17:35 #40486
by uconn_1965
Replied by uconn_1965 on topic Thermostat
I found that the 153 degree or 160 degree are the best. If you use theses thermostats and your Cord runs hot, you have another problem, it’s not the thermostats.
09 Jul 2020 16:12 #40485
Thermostat was created by 1748 S
I recall this subject being talked about but my search tells me nothing.
What is the preferred thermostat tep? I do recall it was to run both thermostats but use the low temp type. Am not sure if the "normal" temp units were 180 degrees or not. Thanks...
