1931 Auburn clutch replacement
- Mike Dube
8-100A
auburnandyscar wrote: Thanks everyone for your help. we have the car on a lift and have a transmission jack. Things seemed very close to not fitting (clearance) and before we got "rammy" ( I know that's not a word) I would ask for advice.
I can only imagine how miserable it must have been to be an independent shop mechanic back during that era.
And, an Auburn is a pretty straight forward car - try a RR PI or a 1931 Cadillac when you need transmission work and it would have been more like the backyard mechanic meets Lockheed SR-71 Blackhawk, Concorde, or Lockheed Martin F-35 Lightning II
- auburnandyscar
Check out my build at:
www.1932auburnsedan.com
- C.R.D.
- Thank you received: 135
mikespeed35 wrote: If you are doing this under the car on your back make a cradle for your floor jack and remove it supported by the cradle. Much easier. On a hoist use a trans. jack for support if you have one. Worth while investment if you don't have one. Just took a oil pan off a 10 Mitchell that I thought was Alum. but discovered when it came down on my chest it was cast iron! Put it back on with the floor jack and cradle. Easy peasy
CORDiallyMike.
Use a magnet next time Mike.. They don't lie as our eyes do all to often...
CORDiallyMike.
- auburnandyscar
- auburnandyscar
It seems (to me) that there is no "easy" way to accomplish this.
*Note* I have more experience with newer cars (1965+) so I may be looking at this wrong (?)
Does the engine and transmission need to be out of the car to get this done?
