Change from side plate engine to 3 and 5 plug Auburn 34-36 engines
11 Mar 2019 22:34 #36837
Replied by Curt Schulze on topic Change from side plate engine to 3 and 5 plug Auburn 34-36 engines
No, #1, & #2 Late 35 #3 Never #4
- yorkgulch
- Thank you received: 18
11 Mar 2019 21:21 #36836
by yorkgulch
Auburn 851
Replied by yorkgulch on topic Change from side plate engine to 3 and 5 plug Auburn 34-36 engines
So a mid 35 car might have any of those blocks?
Auburn 851
11 Mar 2019 21:11 #36835
Yes, among other casting changes.
- yorkgulch
11 Mar 2019 21:08 #36834
by yorkgulch
Auburn 851
Curt,
Is the 4th engine the 5 plug one with supercharger lugs on right side?
Auburn 851
11 Mar 2019 21:00 #36833
There are four different eight cylinder blocks. There are no serial number break downs. From the factory, you may have a earlier engine in a later car, but a late engine in a early car ; probably not.
- yorkgulch
11 Mar 2019 14:57 #36832
by yorkgulch
Auburn 851
Mark, the inquiry is not for that car. It's for one I'm considering.
Auburn 851
10 Mar 2019 22:44 #36831
by ilikescars
Replied by ilikescars on topic Change from side plate engine to 3 and 5 plug Auburn 34-36 engines
I don't know the answer to your question, but I do know that your cabriolet is very early 1935 production. Number 60 off the line
- yorkgulch
10 Mar 2019 16:22 #36829
by yorkgulch
Auburn 851
Change from side plate engine to 3 and 5 plug Auburn 34-36 engines was created by yorkgulch
Is there any estimate of at what serial number 1935 Auburns started using the 3 and then 5 core plug engines that replaced the side plate engines? Curt's Auburns Midwest site just says early to mid 1935.
Craig
Craig
Auburn 851
