Front Hubs for Wire wheels 1932 Auburn
- ttcinc
18 Jul 2018 14:28 #34982
by ttcinc
Replied by ttcinc on topic Front Hubs for Wire wheels 1932 Auburn
Great Thank you
- auburnandyscar
18 Jul 2018 14:16 #34981
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic Front Hubs for Wire wheels 1932 Auburn
- ttcinc
10 Jul 2018 19:50 #34948
by ttcinc
So V12's have bigger spindles? 7/8 instead of 3/4?
Thank you
Thank you
10 Jul 2018 19:38 #34945
by RandyEma
Replied by RandyEma on topic Front Hubs for Wire wheels 1932 Auburn
Possibly somebody changed the hub with a V12
- ttcinc
10 Jul 2018 19:23 - 10 Jul 2018 19:27 #34944
by ttcinc
Front Hubs for Wire wheels 1932 Auburn was created by ttcinc
I am doing my brakes and I found my car has two different front hubs in it. The right one has an OUTER bearing with a 1 15/16 OD and a 3/4 ID and it fits my spindles. The Left one has a 2 1/8 OD x 7/8 ID OUTER bearing with a poorly made sleeve in it to make it fit on the 3/4" spindle. When I look for a 2 1/8 OD x 3/4 ID Taper bearing assembly, they are a special order bearing. Can some one shed some light on this? Did Auburn go to a larger spindle in later years? Thank you for your help.
Last edit: 10 Jul 2018 19:27 by ttcinc.
