18" Snap Rings:
21 Sep 2015 21:46 #30289
Replied by johnmereness on topic Re: 18" Snap Rings:
A lock ring that does not seat correctly may crack in that spot due to stress - so I agree to make sure the rings fit well. I had a reproduction set of 19" wheels and rings and two had a touch of a flat spot in about a 5 inch area (I had them in wheel wells due to timing and someone a shop working on the car later moved them to the ground) - the rings are now in a landfill.
- alsancle
- Thank you received: 17
07 Sep 2015 13:27 #30212
by alsancle
Replied by alsancle on topic Re: 18" Snap Rings:
18 inch snap rings are made of unobtainium. I had coker make up 6 new ones for my Reo Royale. Here is the contact info. You will probably have to send them a wheel so they can make sure the rings seat correctly:
Houston Gibson
Customer Service
1317 Chestnut Street
Chattanooga, TN 37402
Direct: 800-251-6336 Ext. 241
Fax: 423-756-5607
Houston Gibson
Customer Service
Fax: 423-756-5607
- Don Knight
05 Sep 2015 18:09 #30198
by Don Knight
18" Snap Rings: was created by Don Knight
Do you or someone that you know have some eighteen inch snap rings as used on 1928 through 1930 Auburn using Dayton Wire-wheels. I am in need of a couple! Thanks!!
