How is Butler finish chromium done?
- DavidK
29 Sep 2014 01:31 #28252
by DavidK
Replied by DavidK on topic How is Butler finish chromium done?
Thank you Frank, my hardware is chrome now so I might as well try it.
- Frank Guzik
28 Sep 2014 23:36 #28251
by Frank Guzik
Frank Guzik
1931 Auburn 898-A
Auburn IN
Replied by Frank Guzik on topic How is Butler finish chromium done?
Dave,
I chromed mine and then with fine steel wool took the bright off. They look great. Felt really funny doing it but the pieces ended up looking like they should.
Frank
Frank
Frank Guzik
1931 Auburn 898-A
Auburn IN
- DavidK
28 Sep 2014 22:03 #28250
by DavidK
Thanks, that is just what I was looking for. Dave
- Red Brick
28 Sep 2014 20:34 #28249
by Red Brick
Replied by Red Brick on topic Butler Finish
Dave - Here's an old article I found from a Ford site:
www.fordgarage.com/pages/butlerfinish.htm
There's also another site with a 1998 thread about finding a shop that does this type of finish: www.ahooga-archives.com/messages2/7102.shtml
From reading the correspondence on these sites, it looks like the original Butler finish method was to abrade the substrate before applying a thin, final finish plating. An alternative method - which may not be acceptable to a judge - seems to be to apply the chrome as usual and then to lightly abrade it with a red Scotch-Brite pad on a buffing/polishing wheel.
Good luck!
Good luck!
- DavidK
28 Sep 2014 17:54 #28248
by DavidK
How is Butler finish chromium done? was created by DavidK
Can anyone tell me how Butler finish chromium is done? On my 32, the inside hardware is suppose to be done this way. Are the parts chromed and then buffed with a Scotch Brite pad? From what I have seen, it looks like a satin finish. The chrome shop doesn't know what it is and I don't have a sample to show them. Any help is greatly appreciated. Dave
