Oil pressure by first engine start
- gnutting
My 8-98A speedster has a Schebler updraft carb, and tho I've had a lot of trouble getting it to run right, I don't think any of it is caused by the carb design (a shop that didn't, I found out, check ignition or valve timing in seeking the cause of backfiring and low power, convinced me I was at the wrong shop, so am trying again). Certainly it has never flooded.
Jack Triplett
1931 Auburn 898A speedster
- 61xlch
Andy: No problem, its the same topic and my problem is solved.
Go ahead.
Very happy with it.
Some people use a Carter BB1.
Pete
- auburnandyscar
GIVNER wrote: Andy,
On a 12 cyl, there is no check valve between the oil filter and the sump, thus it is very difficult to get pressure once all the oil in the filter drains back to the sump. This problem is exhibited when the engine doesn't run for long periods of time. Remove the center bolt from the oil filter canister and fill with oil through the center bolt hole. Within 5 seconds of cranking, you will see oil pressure. This is based on over 50 years worth of Frank Cek experience. After each driving season for 7 years, I used this procedure after 7 winters with absolute positive results.
Thank you for this info! "could" an accumulator of sorts be fit into the 12's oil system? I love the idea/concept of 'pre-lubing' ANY engine.especially the older more expensive ones! the oil seems to leak back into the pan fairly fast(?)
Andreas- my apologies if I messed up your thread. I will gladly delete my posts if you are offended, that was never my intention. <!-- s:oops: --><img src="{SMILIES_PATH}/icon_redface.gif" alt=":oops:" title="Embarassed" /><!-- s:oops: -->
Check out my build at:
www.1932auburnsedan.com
- 61xlch
tractiondk wrote: Hello Andreas.
If you can't solve the problems with the Shebler carb, then I can recommend Vergaser BOB
www.bobs-services.de/allgemein-en.html
He is a great guy, and a true specialist in carburators.
Torsten
Thanks Torsten. Because I am running a classic car workshop in Germany, I know Bob of course. Basically I am an carburator specialist too (even if not as much as Bob). I have lot of experience with the rebuilt and adjustment of all common post war carbs, incl. Zenith, Solex, Stromberg, SU, Weber, Dellorto, and so on.
I will do my very best to fix the problem with the Shebler carb. But I am afraid this carb could be a constant source of trouble in future. There must be a good reason why these carbs are that rare at driving cars.
I would love to hear from any Auburn owner, that he drives his car since a long time with this carb without any serious trouble?
Andreas
- JOEL GIVNER
JEG
- tractiondk
Torsten
- auburnandyscar
mikespeed35 wrote: One way to eleminate this problem is to prelub the engine with a pressure tank. Fill a clean tank of sufficiant size to hold several quarts of oil. Put air preasure in the tank on top of the oil and inject the oil in to a oil galley plug hole thus prelubing the bearings and filling the oil gallerys. When you start the engine the oil preasure will come up quicker.
Mike do you know for sure that this will work on a 12 cylinder? (not to muddy the OP's comments) when I installed an oil accumulator on my engine, since it does not have 'full flow' filtering it just dumped all of the oil into the pan. regardless of the pressure relief setting.
I plumbed into the filter housing base where the guage/sender goes.
andy
- 61xlch
Engine ran very smooth, but now starts the trouble with my "new" original Shebler TX carb, as I expected. The carb became flooded instantly and we shut off the engine.
Until last year I had a Carter carb, as most Driver-Auburns seems to be equipped with, and this worked without any problem. I think there is a reason why the Shebler TX carb was used only a very short time in 1931, and that most driver cars are no longer equipped with this carb. :rolleyes:
I will see....
Andreas
- Ivor
The Auburn small eight has a well designed positive displacement gear type oil pump of ample capacity. The oil pump pressure is caused by the restriction to oil flow due to bearing clearance and the setting of the relief valve. I can assure you that on a new build with new bearings you will get oil pressure on cranking the motor with the spark plugs removed.
Also, I have really enjoyed watching your build progress, you are doing a very professional restoration.
- auburnandyscar
Long story short- I do not think that these engines crank fast enough, and are not 'tight' enough to build any pressure while simply cranking them over.The pump DOES move oil and lubricate, but not at any "pressure" that we wish to see.
using my drill analogy, its' speed was MUCH higher than the distributor's rotating speed,much like the idle speed vs cranking.
my 2 cents
- Ivor
With the correct amount of oil in the sump the oil pump is below sump oil level and is therefore self priming. After I built my earlier GT engine it took about 10 to 15 seconds for oil pressure to build up. Assuming all the distribution pipes in the sump are fitted correctly the only sugestion I have is to check that the oil pressure relief valve is working OK or not stuck open.
- 61xlch
has anybody experience with the oil pump priming after a complete engine assembly?
Today we turned the engine with electric starter 2 or 3 minutes (without spark plugs). But no oil pressure built up. Probably the oil pump needs to be filled or primed for the first start? Unfortunatly I dont see any possibility for spinning the oil pump without turning the engine.
Any suggestions?
(I am talking about a GU engine from 1931)
Andreas
