steering parts
- K Clark
27 Jan 2014 21:48 #26805
by K Clark
Replied by K Clark on topic steering pivots balls
I do not know if that is what they are called, but that is what I use. if they are the same size as L-29 parts I am having some made now.
K Clark
K Clark
- auburnandyscar
27 Jan 2014 17:11 #26801
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
steering parts was created by auburnandyscar
I am in need of a drag link and a tie rod. specifically,I am wanting (hoping for) info on part numbers or suppliers that might have the ball type socket to mate with my correct pitman arm. (It is 1 1/8 dia.)
I am not sure of the size and taper used on the steering arms. Am I correct to assume these 3 points to be the same?
I have contacted Felix, but quick measurements over the phone did not work out.
