1932 8-100A cannot shift to second
- K Clark
22 Jan 2014 00:48 #26719
by K Clark
Replied by K Clark on topic transmission
It is just a standard trans nothing special, what you will probably find is that your shift lever is worn and you are not taking it completely out of first before you are trying to put it in second, so your alignment balls and spring are the problem along with the pivot pin on the shift lever.
My 2 cents
K Clark
My 2 cents
K Clark
- Auburn
21 Jan 2014 14:29 #26712
by Auburn
Replied by Auburn on topic 1932 8-100A cannot shift to second
Thanks a lot for all the replies
I will investigate further by removing the floors boards and see what is happening.
Haven't tried to shift without using the clutch "like a trucker".., but I did try various engine speeds with the clutch depressed to see if this makes a difference and it didn't.
I haven't been able to find much in terms of shop manuals/literature on transmissions for 1932. I picked up all the manual copies I could find at the ACD Museum last time I went there..there is a hand drawn exploded view of the transmission but not much is written about it.
Your help is really appreciated.
Rob
Rob
- 61xlch
20 Jan 2014 20:20 #26709
by 61xlch
Replied by 61xlch on topic 1932 8-100A cannot shift to second
If you can shift all gears with running engine but stopped car, clutch seems to be fine. There must be a problem inside the transmission case...
- K Clark
20 Jan 2014 17:00 #26707
by K Clark
Replied by K Clark on topic shifting
Have you tried to shift as if you were a trucker who shifts all day with out the clutch, just using the RPM's of the motor with your ear.
- Greg Frownfelter
20 Jan 2014 13:41 #26706
by Greg Frownfelter
Replied by Greg Frownfelter on topic 1932 8-100A cannot shift to second
I think I would take the floor boards up and actually look to see
the bearing moving[back and forth +free rotation} and check clearance
could be an issue in the tower ie. rails and forks
hen maybe something internal, possible worn or broken
thrust washer
go slow and dont over look the dumb stuff
greg
thrust washer
greg
- Auburn
20 Jan 2014 03:41 #26705
by Auburn
Hi Greg
I bought the car recently - it was sitting for a few months while I fixed other things and yesterday was the first time I really test drove it.
No particular sounds besides loud gear clash and strong resistance to the stick when trying to fully force it into second.
I was thinking about the clutch no releasing well, but again, both 1rst and 3rd are switching fine though - and clutch end play seems normal.
- Greg Frownfelter
20 Jan 2014 02:54 #26704
by Greg Frownfelter
how did this begin--after some other work--or just slowly get this way
any other moans and groans going at the same time
that are new
greg
that are new
greg
- Auburn
20 Jan 2014 01:14 #26703
by Auburn
1932 8-100A cannot shift to second was created by Auburn
I cannot seem to be able to shift to second when the car is moving - either downshifting or upshifting.
I tried double clutching, triple clutching, teasing it in different ways with no success - all I get is gear clash and no way to get the gear in.
I also did try different oil weigths to see if this makes a difference - from SAE 140 to 200 to SAE 250 which is the thickest oil I could find - this usually helps some with gear clash on my 1932 Cadillac - but on the Auburn this did not make any difference at all.
When the car is stopped I can switch to second and the stick stays in second just fine.
Are there any adjustements possible ?
The first and second work just fine with no gear clash...its only the second gear.
Rob
Rob
